Add "Change to Array" feature on Right Click for a control or constant.
So many times I have to select the control (or constant), then select an array, then place the control into the array.
On a right click, the panel with a 'Change to Array' selection would be a real time saver.
I didn't find anything that listed this feature, but I figure this would have already been a feature if it had been posted.
