13 | |
7 | |
4 | |
2 | |
2 |
When right-clicking an existing channel wire, the only channel option is to create a Channel Reader. I'd find it helpful to be able to easily create a Channel Writer directly as well, working backwards to the data input.
You can click the 'Switch Read/Write' button in the Select Channel Endpoint dialog to change the direction of the created channel endpoint.
