You cannot currently install MAX as a standalone product- you need to install it along with something else. I need MAX on basically all computers I build my installers for, so I always go into the Additional Installers menu on the Application Builder, then pick (usually) "DAQmx with Configuration Support". Unfortunately, this also means I have to uncheck "Automatically select additional installers" so I can go find the "Configuration Support" item.
I almost always want to let the App Builder pick my additional installers for me, so I will check "Automatically select", then uncheck it, then go check the box for "...with Configuration Support" for one of the items that got automatically selected.
I'd like a box that lets me prefer the "With configuration support" version of whatever I'm building so I can make sure MAX gets installed. For my use, it doesn't seem to matter if I pick "DAQmx with config support", "VISA with config support", etc.
I'd ask to make MAX a standalone installer, but that would require me to uncheck the "automatic" box to add MAX to the list, which doesn't really help. I just want to say "Hey Appbuilder, figure out whatever you need, and ALSO install MAX."
Pro-grade mockup shown below:
