| User | Kudos |
| 12 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
There should be an option to choose which version of LabVIEW want to
build your application, so would only be loading the vi's corresponding to avoid
version compatibility problems.
Further updates NI LabVIEW should create, so each developer would install
the latest version and any patches that were wanted to use.
If I owned the LabVIEW 2010 and would want to work with 8.6 would install
a patch for this version and not like today having to install the LabVIEW 8.6 whole
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
