In 2014 the Clear errors VI now accepts a single error which can be cleared. This is nice but when I heard NI was implementing their own filter errors, I assumed they would do it in a similar way to the OpenG Filter Errors VI, which accepts a scalar, or an array of error codes to filter.
In addition to this I think it would be helpful if this Clear Errors also accepts the error data type for errors to filter, or an array of errors to filter. That way the Error Ring can be used to help readability of the block diagram showing the error that is being cleared.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
