| User | Kudos |
| 13 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
I'm not sure if someone has requested it yet, but it would be very helpful if I could clear the probe watch window of the last retained values. This way I don't need to look at the timestamps and it will speed up the debugging.
