5 | |
5 | |
2 | |
2 | |
2 |
Today, if you right-click and select Clear Chart, on a waveform chart with absolute time on x-axis, it will reset its time also. This means that if your LabVIEW loop started adding to a waveform chart once a minute two days ago, Clearing the chart will make the time restart back two days ago, even though you are adding new data now, not two days ago. I wish NI would implement this feature in the next version. :manvery-happy:
