6 | |
6 | |
3 | |
2 | |
2 |
When you navigate through Labview code and go deeper in VIs hierarchy you end up with dozens windows open on your monitor.
Lets create special action for opening subVI (like existent Ctrl+RightDoubleClick) which will close FronPanel BlockDiagram of VI from which you open new one ?
