Greetings:
There were couple of related posts on Close Reference. I did a search and found these. I am posting it here for reference. Link1, Link2.
I am suggesting that anytime we use an item from Application Control palette or an instance where an application reference needs to be closed, a Close Reference item also be automatically placed in the block diagram. This would be very similar to how teststand handles Flow Control. So when a Close Reference is always dropped, it suggests good programming practice to close all references from the subVI/VI. Ofcourse LabVIEW will have to determine the best location to drop the Close Reference.
