6 | |
2 | |
2 | |
1 | |
1 |
Use "tab" to tab through the text fields and map enter to the ok button.
This would streamline the dev process when creating lots of vis. It allows to double-click icon --> enter first line --> hit tab --> enter second line --> hit enter --> voilà.
As both my hands are on the keyboard at that point, this would prevent me from reaching for the the mouse all the way at the far end of the keyboard to click ok.
Pushing LabVIEW efficiency further and further, one second at a time!
As it takes on average 1 second to hit the ok button, if that feature is ever added, i will have to create approximately 300 VIs in order to make that posting profitable...but that is just for myself, think of the millions of seconds that will be saved every year on the planet!
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
