While some ideas like this suggest that we should be able to open block diagrams without opening the front panels, and others suggest that we let go of the front panel as the primary part of a vi, the front panels will probably be around for quite some while yet. But the block diagram is where we primarily work, and closing a vi requires clicks on two different windows. Using ctrl+w twice is not working since the second last window is not always the FP (if it's your very large project this may be annoying).
Let us have the possibility to close the entire vi including FP from the BD by ctrl+click the panel close 'x'. Similarly, remap ctrl+shift+w to close the entire vi.
