FlamingYawn
Cluster Justification
Status: New
When set to "Arrange Vertically", clusters are always left justified.  I would like to be able to right justify the cluster contents while still keeping them verically arranged.
Robert Mortensen
CLA, CLED, LabVIEW Champion, Principal Systems Engineer, Testeract
5 Comments
JackDunaway
Trusted Enthusiast
Yes! Cool! But the screenshot you provided only aligns the justification of the TEXT, not the control itself. What you want is the control alignment:
FlamingYawn
Correct!  That is the right way to do it, thanks for pointing that out.
Robert Mortensen
mavimi
Thats easy when you have a cluster that fits within a screen - however if you have big cluster that you have to scroll your way down to se all the controls - its quite cumbersome to align the items to the right.
It could be nice if the current context menu item : "AutoSizing -> Arrange Vertically" was changed to two new items:
AutoSizing -> Arrange Vertically - Align Left
and
AutoSizing -> Arrange Vertically - Align Right
or just change the current command to default to right alignment.
AristosQueue (NI)
NI Employee (retired)
Never mind. Just saw the other post from mavimi which has my same proposal.
AlexElb
Any update in 2025? Do we have a better workaround than placing the elements manually right aligned into the cluster? Maybe a QD plugin or something?
Proud developer at Hampel Software Engineering where we turn '404 not found' into '200 OK'. Join us on Discord
