Eventhough the Size To Text setting of the caption of a (even Strict Typed Def.) cluster is unchecked,
it will be checked by default when placing this ctl on a FP.
Obviously, if you don't modify this unexpected setting before editing the text, the caption will resize.
But much worse : if the text isn't changed, the caption will not resize in the developpement environnement but it will in the executable !
Bug or idea ? Please change this annoying behavior.
