"code frames", similar to decorations, may be used on LabVIEW block diagrams to separate code groups according to function or preference. Cleanup feature may be disabled within a code frame, allowing the wires, icons, and comments to remain in place. Wires crossing boundaries can be locked to the boundary as well. The idea is to allow functional groupings of code without using subvi's, and to prevent cleanup feature from morphing the block diagram layout continually during the development of a VI.
