10 | |
3 | |
2 | |
2 | |
2 |
I have 208 data producing test stations, located in 10 different labs in 4 different countries.
I need an easy way to copy or move the files from the test stations, to a lab data computer, to a “web service” to a master global data base in the US.
Within each test lab I am thinking a network shared drive.
However, getting the files from China, Taiwan and Germany to the US automatically is challenging.
I am thinking that a web service like “amazon web services” would work. But setting it up and programming it into LabVIEW is more challenging than it should be.
It would be really nice if Nation Instruments would create a simple easy solution to do this.
