10 | |
3 | |
2 | |
2 | |
2 |
There should be an option to let broken wires have color. Wires connected improperly may not need color, but disembodied wires that have one end or the other connected and one end disconnected should have the dotted color of the original wire so that they can be reconnected easier. The little arrows could stay there to indicate direction and source.
