the two string array should be added in that way, shown in the top of the picture.
It is possible to use two For-Next-Loops. But the "Combine Sting" already
allow the input of Arrays (see bottom of the picture), but the result is a
single string. It would be nice if it is possible to select the type if combining
the input (like it is possible at "create array").
E.g. right mouse click on "Combine String" -> Output String or Output Array
