2 | |
2 | |
2 | |
2 | |
2 |
Wiring complex time waveform or complex wdt plots only the "I" or real portion of the complex signal. It should plot the Real and Imaginary as two plots overlayed. Always have to do that when plotting complex data and wastes time and clutters the diagram as well.
