paul_cardinale
Compound Arithmetic with inverted input should be easier to spot.
Status: Declined
If an error cluster is wired to an inverted input, it can be very difficult to spit the 'invert' bubble.
Something bolder should be used to designate 'invert'.   E.g. a larger circle, or a different color for the input box, or a symbol inside the input box.
3 Comments
crossrulz
Knight of NI
At least related: Enlarge the Invert Circles
TomOrr0W
Looking at the comments on this idea, I ended up searching invert, negate, bubble, and circle (skipping anything that was already marked duplicate).  I figured I might as well link the related ideas.
Strongly Related:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Enlarge-the-Invert-Circles/idi-p/1023748
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Replace-the-Invert-Circles-in-Compound-Arithmetic-Nod...
Related:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Offer-a-Positive-Logic-Alternative/idi-p/1022834
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Negate-option-on-Comparison-functions/idc-p/3793254
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Shortcut-to-Invert-Input-Output-in-Compound-Arithmeti...
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Correct-the-quot-not-quot-symbol-by-removing-the-inve...
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Automatically-invert-compound-arithmetic-inputs-when-...
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/General-Comparison-Operator-as-an-Express-VI/idi-p/12...
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Simplifying-Boolean-expressions/idi-p/1890963
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Invert-Option-in-all-Boolean-Terminals/idi-p/1281058
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Invert-signal-going-into-a-select-VI/idi-p/2224232
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Negate-input-on-boolean-functions/idi-p/1084159
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Array-String-not-empty-function/idi-p/3163821
Darren
Proven Zealot
Status changed to: Declined
