9 | |
3 | |
3 | |
2 | |
2 |
Currently we can set Conditional Disable Symbols (CDS) for a whole project or for a target.
I wish we were able to set them inside a build spec, too.
This would mean, I could have a large application in one project and build different flavours of it's executable simply by using the appropriate build specs.
Use cases might include simple things like debug / release builds (similar to this idea), but also more complex differences like a software that uses real hardware and a special version that works without hardware, which can be used in the office.
Currently I need to either set the CDSs manually each time I build an executable or maintain several copies of the same project file. Both methods are tedious and error-prone.
