11 | |
8 | |
3 | |
3 | |
2 |
It would be useful to have a configurable tool for generating swept values for RFSA/RFSG mainly.
This is actually present in Signal Express. You can insert and even nest the "sweep"-step here, but as far as I can see SigEx doesn´t have support for RFSA/RFSG.
So the next thing coming to my mind was to export the configured sweep as LabVIEW code from SigEx. Unfortunately the resulting Express VI cannot be converted into a regular subVI.
It would be very useful for debugging and prototyping to get this feature!
kind regards
Marco Brauner AES NIG Munich
