Randall_T
Configurable dialog with timeouts and default capabilities
Status: Declined
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
I would like to have a native LabVIEW dialog in the functions pallet that will allow you to set a default value and a time out feature.  This allows a user to pick a desired behaviour if present but if not present the dialog times out and program continues to run with the default action in mind.  It is relatively easy to create the interface needed but there are times having this already available would be great.
3 Comments
Anthony_de_Vries
Doesn't it make more sense to simply make a template vi for yourself, with the desired functionality, and use and/or extend that?
Randall_T
Sure you can make a template as you can with most vi's on the functions pallet. It would be convenient to have this built in so it would be available I suspect many people would find this useful.
Darren
Proven Zealot
Status changed to: Declined
