11 | |
11 | |
3 | |
3 | |
2 |
It would be nice, if during installation of LabVIEW, installer will configure Firewall as needed for LabVIEW. For example, Network Streams - is standard LabVIEW feature, but to use it, one should manually configure Firewall (as described in this KB article). I'm sure, that there are other cases when similar should be done.
Of course, then exe anyway should be added to Firewall exclusions list, but at least one could use and test Network Streams out of the box, without googling out why it does not work...
This feature could be optional during LabVIEW installation, but if it is possible to automate something - then better to have it automated, then refer to some manuals and KB articles...
