Adding an option of configuring values to the functions like comparison, calculation will make the things much easier.
I Understand that this will be having limited use only as we can use this only when we are comparing the value with the predefined value but it still make sense for me to post it and I will add kudos if it has already posted.
1. The code looks simple
2. Save the use of Numeric memory
