Sometimes you want to have a set of VI with the same properties of reentrancy, for this, we can consider the option of having a virtual folder with the option of reentracy desired, as it happens with the option of access scope.
I propose to have the option to define a virtual folder with a properties of reentracy and that VIs are contained in it, change its property. In this way, I think it is easier to know the properties of the VIs reentrancy.
Regards.
