Downloads and updates that self-extract to an installation image are often placed into different folders under "\National Instruments Downloads" even for very similar products or even updates to the same product.
For example, LabVIEW 2012 extracts to "\LabVIEW English\2012" but the f1 update extracts to "LabVIEW Development Environment\2012 (32-bit) f1"
The 2012 Run-Time Engine extracts to "\LabVIEW Run-Time Engine\2012 (32-bit) f1" while the 2011 Run-Time Engine extracts to different folders depending on which update it is.
The 2011 f2 extracts to "\LabVIEW\Run-Time Engine\2011 f2 32-bit\Standard" but f3 extracts to "\LabVIEW\2011f3\Run-Time Engine\Standard"
This can make it difficult when looking at one of the top level folders to know what it contains. Is it a Run-Time Engine, an update ,or a main program file ? If the main program and all its updates were under one folder, then by copying just that one folder one would know that all files and updates were included in the copy.
Steve
