6 | |
2 | |
2 | |
1 | |
1 |
When you get an error from an invoke node or property node, the error message sometimes tells you which node generated the error. But it often does not. It'd be nice if these error messages always provided you with this info:
I've spent plenty of time in the past trying to track down the exact node throwing an error, this simple change would've saved me quite a bit of headache.
