see original post from gt3000
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Progress-bar-when-loading-dependencies/idi-p/2898166
i liked the idea too much to leave it like this!
When you launch a vi you always see the very unprofessional window that shows a lot of information that the end user is not interested in, the original idea comes from gt3000 who proposed the following.
Proposed New User Experience:
To get back to Classic User Experience: click 'more...', or if a dependency cannot be found:
It was rejected due to understandable reasons but with the wrong mindset, i would alter the idea like the following. instead of using a static progressbar that goes from 0-100 and where you indeed need to know the end point (issue why this idea was rejected). use a continuous progress bar like the picture below. this gives you the same output, a cleaner, more professional looking window.
Kudos if you like!
