| User | Kudos |
| 14 | |
| 4 | |
| 3 | |
| 2 | |
| 2 |
The Current Situation:
In a LabView Real Time program Control References cannot be used because the front panel is removed (even if debug mode is enabled). In order to write to a control in a cluster, the only options are to use unbundle/bundle or variants. It is preferrable to be able to programmatically write to any control within the cluster when one is required to be able to change any value within a large multi-level cluster that has many controls. Using variants and drilling down into the cluster to access and change a value causes execution issues in a Real Time program.
The Idea:
Have a Control Reference Terminal on the Data Value Reference Read Node on the InPlace Element Structure. This is shown in the code below.
This would allow the value (and whatever other properties make sense to be accessible) to be programmatically modified inside the InPlace Element Structure. This would work in the Real Time environment too.
