6 | |
5 | |
2 | |
2 | |
2 |
When you right click on a Control, Indicator or Constant terminal, you get the options to change it to the other two. A new option to Change to Local Variable would replace the terminal with a local variable for that control and put the terminal grasped by the mouse for the user to place on the block diagram again. In the case of a Constant, it would replace the constant with a Control first.
