13 | |
11 | |
3 | |
3 | |
3 |
I have an application that tests three products at a time. When a product is put on test, the user enters the serial number of the product, which pulls up the Excel datasheet for that product serial number.
The datasheet always comes up in the last saved location within the Excel window. I would like to control if this file appeared on the left side (where it currently is), center position, or right positon. Please see the attached screen shot.
It would be nice to force the datasheet to open in a certain location in the window.
