After reading a rather heated discussion about converting Globals to Functional Globals, I was made aware that you can convert the Shared Variables to Globals, but not the other way around. How strange.
I will not enter the debate that I liked Steve's idea, especially for debugging purposes. But what if we could convert the Globals to Shared Variables? They have the error cluster in and out.. Which would force dataflow. Much better than wrapping the Global inside a Flat Sequence Structure and run the error wire through the Flat Sequence in order to force dataflow.
I did a quick search and to my surprise, I did not see such an idea being proposed. Apologies, if I missed it.
I do offer these links if you are interested in reading the other G to FG discussions.
