Actually if you have a vi in a Xctrl library and you want that code to be a property or method of that Xctrl you must create create a blank property or method and copy that code into the new property or method vis. I think it would be a really nice to have, if we would be able with a simple right click in the subvi of the subvi if we had a option that allows us to "Make subvi to property" or "Make subvi to method".
