Maybe I have just created bad habits, but often times I copy a control on a BD that is the datatype I want. Then I go to some other VI and open the front panel and try to paste it, but I can't. I would like to be able to copy a control or indicator from the BD but paste it to another VIs FP. The reason I want this is because if I have to paste to the BD because I copied fromt the BD, sometimes it puts the control in la-la land away from all my other controls or indicators on the FP. If I could just paste directly to the fp, I could put it where I want.
Could I double click the control to find it then copy from the front panel? Yes, and maybe I should have made this a habit. But because I have not this lack of functionality sometimes annoys me ![]()
