Steve_TDiode
Copy file function create non-existing folder path
Status: New
The Copy function when used to copy a file to a folder that does not exist will generate error 7.  Having an option (an input to the Copy function) to create the folder path leading to the file to be copied is desired.
4 Comments
crossrulz
Knight of NI
Similar idea (NOT a duplicate): Open/Create/Replace File Function - create file's path if it does not exist
ConnerP
For anyone else that may come across this issue, the OpenG Toolkit offers a pretty quick solution to this problem
crossrulz
Knight of NI
You don't even need the OpenG Toolkit.  You can just use the Create Directory primitive to create the folder.  But do note that this primitive will return error 10 if the folder already existed.
ConnerP
You are right. I did not realize the primitive also handled multiple levels of non-existing directories. I guess it does say right in the detailed help "This function creates all folders that do not already exist in the specified path". RTFM I suppose...
