When a folder is copied that contains (subfolders with links), the folders are not copied OK.
The copy command follows the shortcut/link and tries to copy that target.
(did not test it in detail yet, but I get a 'error 7' when copying a shortcut pointing to a no longer existing target. If the same behavior also is happening on 'move' or 'delete', following the shortcut may lead to very *unpleasant* suprises...)
