13 | |
11 | |
3 | |
3 | |
3 |
When using refnum arrays with auto-indexed tunnels in loops, I often bump into the absence of the submenus "Property for <ClassName> Class" and "Method for <ClassName> Class" in the "Create" Menu.
The submenus appear when right-clicking normal tunnels, shift registers, wires, subVI terminals, Constants, Controls, everywhere, except for auto-indexed tunnels.
This idea is a revival of an old post from Darin.K : https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Create-Property-or-Invoke-Nodes-from-Auto-indexed-tun...
which has been declined in 2015 for too low priority reason, but since it is still annoying now (e.g. with LV 2018), especially when using VI server (dynamic VI calls, UI elements manipulation, VI Scripting...), I think NI should reconsider it.
