I have recently been using more test vectors in the unit test framework.
The principle works well but if you are in a unit test and decide you need a test vector you must:
This seems convoluted and forces unnecessary context switchs.
I propose that at a minimum, you should be able to create a new vector file and launch it's configuration without leaving the unit test configuration window. I suspect that the whole process could be streamlined even further though.
