| User | Kudos |
| 12 | |
| 12 | |
| 9 | |
| 8 | |
| 4 |
I use single process shared variables quite often and I am always amazed how much space the take from the block diagram. As they requires room I either make long VIs or play with the wires. Not good...
The current situation:
So why dont we have something similar than what we have with property nodes, but applicable to the variables we have in the project? Each variable can be set to read or write, same as the properties of a UI element.
The proposed solution:
I dont have too much experience with locals and globals, but I guess this idea could be applicable for those as well.
