11 | |
8 | |
3 | |
3 | |
2 |
There seem to me to be a couple of choke points in right-click access to VIs and functions. One is that I frequently need to use the same VI's repeatedly. Another is that the quite useful "insert" and "replace" context items only offer a few first-tier options: one or two related palettes, or all palettes. Try to insert a few datalog functions for example, and you have to navigate down 6 levels for each. It's even worse if you have to use "select a VI..." and browse to it. For the worst cases, insert and replace lose their advantage over copy-paste or quick drop.
I propose a dynamically generated palette consisting of the last several VIs and functions (even controls) that have been dropped. This is analogous to recent-commands-list functionalities common in CAD packages.
- As a member of the functions palette, the items in it are at or above the level they are in their normal place in the hierarchy.
- Since it's a palette you could pin it and it would be handy for dropping the same node on two different block diagrams
