Hi
It would be nice if it was possible to create a empty folder with the installer.
I have an application to handle some files that are generated by other applications. Therefore I require that there is some specific folders which these programs can place their files in.
I know I can create them by placing a dummy file in the created folders, but I think it is a mess with non relevant files.
Regards Bjarne
