It would be nice to have the Create SubVI option with the block Diagram right click option.
Please explain how this is an improvement over using the menu option Edit >> Create SubVI which already exists.
be careful with the number of menu items when rightclick. no kudoos for this one
Ctrl+T is by default reserved to "Tile Left and Right". Never used it, so it is now used to creaTe a new VI...
After nearly 7 years, NI has implemented it. Thank you NI for implementing.
