DrK.Jimenez-Marquez
Ctrl+Click while wiring change the cable source
Status: New
LabVIEW has the capability to swap inputs on some nodes using the 'Ctrl' key. However, when we need to insert a functionality between two nodes (whithout QD) or we have to change the source of a cable, we have to wire first and then delete the branch from the previous source because the wire become broken. This become a mess if the auto insert feedback node option is enabled.
I suggest the modulation of the wiring with the 'Ctrl' key:
PhD. K.Jimenez-Marquez
Let's make it simple!
