| User | Kudos |
| 1 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
In Front panel when a button is created it will have default Label name so when Ctrl + Click and Drag the a new button identical to the button will get created and the label will be created with a number. This should also be applicable to Boolean text I never came accross a situation to have two buttons with the same boolean text.
I guess this would be useful.
