5 | |
3 | |
3 | |
2 | |
1 |
In the spirit of Ctrl + double-clicking a subVI to open it straight to the block diagram, Ctrl + double-clicking a type def control / constant / indicator should open the type definition. Just a bit quicker and more convenient than right-click -> Open Type Def.
This functionality is already available with the following setting:
Tools > Options > Front Panel > Open the control editor with double-click
This works on both the front panel and the block diagram. Note that when you're using the Auto Tool, the double-click must happen on the edge of the control/indicator/constant.
