13 | |
8 | |
3 | |
3 | |
3 |
When using the insert quick-drop option, it works great when wiring something into a single wire.
However, when working with multiple wires, it just inserts a new VI on each wire. This could be improved upon to better support the standard LVOOP workflow where you'd want to pass two wires through each VI.
I find that this is the scenario where the quick-drop option could be most-useful, however the current implementation really isn't very useful in this scenario at the moment.
The Ctrl-Shift-I shortcut with Quick Drop allows inserting a single object on multiple selected wires.
