| User | Kudos |
| 14 | |
| 13 | |
| 9 | |
| 4 | |
| 3 |
Long, long ago in a LabVIEW version far, far away there was a simple Scrollbar Control that was fully customizable.
Somewhere around LV8.0 (?) it mysteriously vanished, and now when you select a scrollbar from the Modern>Numeric palette, you are given a bog-standard system scrollbar instead.
Now don't get me wrong... I LOVE using system controls and use them whenever possible, but there have been a few times where I have really missed my customizable scrollbar.
I recently developed a lovely black XControl scrollbar with properties that mimic the system scrollbar but it was a lot of work, and it still lacks some of the flair of the built in version (like scroll-wheel response, click and drag resizing). Plus, it requires a bunch of extra VIs to be in memory that didn't need to be there before...
Wouldn't you love to see the good old customizable scrollbar reinstated?
