JackDunaway
Customize Properties and Methods Menu for XControls
Status: Declined
National Instruments will not be implementing this idea. There is no further feature development planned for XControls.
XControls inherit from ancestor object types (Control and GObject, namely) properties and methods that I would like to hide from the public API shown on the "Create..." context menu. Why do I want to hide these methods? Those properties or methods have the possibility of placing the XControl in an undesirable state, or possibly I have created "Override" implementations as a User-Defined property or method ("override" may not be a technically correct term here, but it conveys my intention).
I envision a tree control on the XControl Properties dialogue that contains a hierarchy of inherited properties/methods. Each entry would have a checkbox which controls whether the property/method appears on the API context menu. If, for some reason, there are some properties that should not allowed to be hidden (as determined by R&D), a disabled-and-greyed checked box would be appropriate.
(I don't expect these properties to be disabled - if you were to upcast the XControl ref to Control, you would see all the default properties/methods again, and they would perform their default action. This action may be discouraged by the XControl designer, but still permissible by LabVIEW.)
2 Comments
PhillipBrooks
Active Participant
Darren
Proven Zealot
Status changed to: Declined
