13 | |
11 | |
3 | |
3 | |
3 |
It would be helpful to add an option like "Digital Value" in the DAQmx Trigger.vi (comparable to Analog Window).
Background: when missing the edge of a digital trigger signal (due to being late in code execution after eg. waveform reconfiguration), the trigger event does not happen. With this new option it is possible to execute the trg event asap after missing the edge.
