I'm a new user and have noticed data are put into folders with the project date as the name. An Example is: 10152012_111940_AM.
In one project I generated several folders which I realized cannot be sorted chronologically by name. My suggestion would be name folders using this format: YYYYMMDD_HHMMSS where HH uses the 24h clock. That way folders will sort chronologically. So the above folder would be 20121015_111940. The attachment shows a folder with renamed files.
